Ok, got it! Although a pair of SL2s would cost probably just a fraction of what you paid for the NAP 500. A listening room is only as good as your ears can tell, I’ve learned.
Thanks for the thorough considered reply.
Enjoy it!
Shame you are not closer, I would bring my XOs for you to try.
M
beautiful pair of SBLs!!!
Hi Massimo,
good to see you back here. The forum is a better place with your posts. Are there some similarities between your new electronics and the Bow you had quite a while back (I think you mentioned either a Wazoo or Wizard)?
That looks very nice with the low Fraims. You might like to try aligning the Naim boxes with the front edge of the glass - it should sound better that way. It shows the dust less as well!
Very nice.
Can I ask the make of your wall panels? I’ve seen them in other’s posts but keep forgetting to ask…
I’ve recently been experimentally covering the large mirror in our room, similar to how you’ve covered your TV…
The dinosaur is cute too!
What is your js2 for? I had one before.
I use js2 to power
etherregen and nucleus +
Vicoustic😄
Thank you. Actually, I did it on purpose, because there are two children in my family. I’m afraid that one day they will bump into my black box.
So glad to see you post, Max. Stay safe and healthy.
Thanks!
Yes, that’s right - though they have been quite heavily modified.
I finally got my S40’s out of the book case and onto Dynaudio Stand 20… The room is hard to photograph with the different lights etc. Shot of the Room, shot from my Listening seat with grills off.
![IMG_9264|666x500]That’s a pretty impressive room.
With my imagination and poor accurate eyes, I see 4 statements in front, inside the chimney.
That’s funny. Thanks Rooster
Thank you Pete. I sounds pretty good too
I should imagine those sofas must block the sound at the “listening seat”?
