Clean lines and elegant setup. Nicely done!
It’s a very nice, clear and clean system
I am satisfied so far! They are very suitable for my small 10m2 office
My cat strayed into my last picture as well.
If you wonder what I meant , if your recording is a sow’s ear you can hear the honk, if it’s a silk purse you can feel the smoothness.
Anders, what are those either side of your NBLs in the bottom photo?
They make NBLs look very small. They look like DBLs but I have not seen that veneer before.
Best regards, BF
…and beautiful (Vitra, I suppose) coffee table too…
These are old Snell A3i speakers - almost identical dimensions to DBLs. 4-way acoustic suspension system with a 12 inch downfiring woofer and a backfiring super tweeter. Magic sound including a midrange to die for
Noguchi coffee table
Hej Anders, shouldn’t the Snells sit roughly where the NBLs are placed, or are you just enjoying 2 pairs? Best Peter
Yes Peter, you are right. They should be moved a bit closer and away from window, but enjoying both speakers at the moment
Well done
No room acoustic problems, as the speakers are very big and the room not so big and not high ceiling?
What are the boxes on the floor at the right?
The is quite big it self 40sqm plus, one is a audiophile switch/lps the other is the nucleus
Which switch? For Nucleus, I was unable to read it.
How do you get on with the 555 Streamer and 552 with the 300DR. I am close to that, Happy with the 300 at the mo. Just for the 552 and its bedding in well. Same speakers, fraim and lume cables
