Do you have two power amps ?
Are you using some sort of LED strip to light up glass platforms, or it it purely a reflection from the table lamp?
Looks good though
Looks great against the Naim logos ā¦ do tell, I feel a project coming on.
I noticed that and liked it as wellā¦
Hi.
RGB LED strips facing the wall so the light is reflected rather than direct (too bright). The glass impacts the pass through colour so itās more a yellow than green output from the leds.
No. Two Supercaps - one for the 252, the other for the Superline.
Hi Kev, Iām intrigued with the LED setup. Did Paul supply a kit or was it pre-fitted? Iām wondering if I can do a retro-fit? More info would be great if possible please.
I also liked the green glow in the glass shelves. My only concern is LEDās can be a little noisy so near to a hifi system, and possibly sharing the same ring main.
Yes for two pairs of speakers.
Why not get some Christmas tree lights and a glitter ball while you are at it? A hifi system should surely be as discreet at possible, not lit up like the Blackpool illuminations. If you want coloured lights then a Chord system might be the answer. Less is most definitely more.
Nothing good to say, best to say nothingā¦
Duly notedā¦
Thatās just what I was thinking, especially as thereās a Superline in there, so presumably a MC cartridge. Most LED lighting belts out high levels of noise.
Each to their own.
Thank you.
Sorry, that was not up to-date. It is now!
Silly boy.
