System Pics 2021
A used NAC 252 has just arrived and been slotted in.
Despite being cold and unused since it was serviced it’s already shown the 282 a clean set of heels. It’s really lovely.
I think I am pretty much done now unless some unexpected money comes my way.
That looks lovely but any chance you could centre the box at very bottom? :wink:
No chance :laughing:
Thank you, it’s the 555 DR and it must have moved when I was faffing around with the burndies!
Normality resumed.
Would be better toed-in though…
What a neat and clean looking system/room. I also love those AN speakers. You’ve them quite far out into the room than from others I’ve seen/heard. How do they sound if they’re pushed back with only 5/6" from back wall (as that’s where I’d need to place them)?
Please don’t go there!!
The ones of which I spoke appear to be toed in.
I was referring to the socks, with the toes sticking out!
I also had it close to the wall, unfortunately way too much bass in my 33m2 room
And then use for cleaning the car
You touched the Burndys?? You like danger.
I did and now they are not touching anything!
They are a PITA in a single rack, I’ve got 5 of the buggers now to contend with. The corner location makes it a bit easier as there’s quite a bit of space behind the Fraim. It’s a bit tight at the extreme left hand side which is how I caught the 555ps and moved it when removing the mains plug our of the NAPSC.
Sorry - I’ve been a day late and a dollar short my whole life! :crazy_face:
Could do, I use old boxer shorts to clean the windows they do leave streaks then I remember to wash them first :wink:
33 m2 ? Not a typo error? Because it’s a big space normally.
Back on topic, system 3
Should give plenty for people to complain/point out is wrong🤔
Raidho bookshelves?
Not quite. I wish, and yes Raidho was the inspiration. I’ll see if I have a better closeup of speakers and stands for you.
Edit, slightly clearer picture before NDX arrived a few weeks ago.
Speakers are based around IPL M3 but my cabinet design. Stands DIY Also. All built by me.
They are designed by you?
