That must be O’93?
Did you buy the tin edition package and “throw away” the Focals?
I think they looked like O93s too.
Does that make you both Bread fans?
Is this your listening room or dedicated listening area in the HiFi store?
There does seem to be a lack of something to play those records on.
Haha, Yes I suppose it might, although I do prefer mine toasted.
Better not to be in the grip of a tyrefitters hand though!!
I do like that ProJect TT …
Put those grilles back on
Thank you, I will definitely look into them. Probably best to take delivery of the loudspeakers first, though.
Thanks Stover.
Your old turntable, I assume?
That’s looks beautiful.
You’re not so bad yourself
This is my personal listening room. The O/93s recently replaced the O/96s as the step down in sensitivity seemed to pair better with the 300 DR.
As for vinyl, it’s hard to tell but there is a RP10 positioned behind the right speaker.
Did you lose out a lot in overall sound quality going from 96 to 93?
Not at all.
I ran them side-by-side for a couple weeks before making the decision. In the end, the difference was my preference of running the 282/300 DR at about 8 vs 7 o’clock for everyday casual listening.
At first glance, I thought you had one of those fancy Shunyata Research Denali power blocks.
Lovely room and system
