System Pics 2024
If my dear Dad was still alive, he could have a chat with you about les elephants :grinning::heart:
I have bought a wall bracelet. Not installed it yet and not sure I will. From our position I would have to raise the height of the tv position by around 30 cm, to be able to install the amp on this tv rack.
Inside, there is not enough place and height for the amp .
Under the tv, inside the rack, there are some SMPS, the router, cables mess, a linear ps for the router.
I really need a higher and bigger tv rack.
Now I know the elephant in the room :slight_smile:
Those look like Birkenstocks you are wearing. I have the same exact model!
They are the only slipper that can keep my feet warm during the winter months. I love them!
Monotone version.
DG…
Monochrome Version 2.
DG…
The title track says it all. That’s what happens when you move away from naim…:wink:
Move back then :laughing:
@GraemeH
Good one.
DG…
For those who wanted to help with my Ear 534 installation, I found this rack and ordered it.
It will replace my tv rack. The tv will stand above it and the amp on the first bottom shelf.
I will remove the 2 middle shelf to give the amp enough air. The dimensions are perfect and it looks very solid. I will just add the same isolation I have now on the floor :
LPH
610565780mm
Poids du produit
15.5kg
Poids supporté (étagère)
50KG/20KG/20KG/50KG
Matériaux
Bois MDF, Fer
A nicely different-styled rack FR :ok_hand:t3:
Look forward to seeing in situ…
I would quite like one of those in the khaki frame with the mahogany finish shelves. Looks smart.
Edit: Maker info says Camel frame and Walnut shelves. My mistake.
Is that really needed? It looks like there would be plenty of room and the shelf will provide some additional protection for the amp.
With the amp on the bottom shelf, the middle two could be used to keep food warm at dinner parties.
So what you’re saying HH is to use the shelving unit as a hostess trolley? :rofl:
Exactly so!
The bottom shelf for the amp, the higher shelf ( where the turntable sits on the pic above) for the tv. ( the tv has a little stand platform).
Fitueyes Eiffel
Made in China. Only 140 euros.
I look forward to seeing your Ear 534 sitting on it. Should look really cool and then it’s out of the way. I would keep the other two shelves on it and use them for something else. Maybe some ornaments!
Or a lamp :face_vomiting::face_vomiting::face_vomiting:
