System setup HCDR HC flatcap 2x cd5x
I just bought a HCDR.(Upgraded version).
This one will replace the HC non DR which is powering the 282. I hope this will give a better SQ.
So I do have a spare HC. Will the SQ improve if I connect the HC non DR to the cd5x, in stead of the flatcap 2x? I also use the flapcap for powering the stage line. Must I also change that, so that the stageline will be powered by the HCDR through the 282?
Mostly I play cd sometimes the TT.
Any thoughts on this.
Since you have the spare HC may I suggest you try all the options above and let us know what you hear. I for one would be very interested in knowing about your experience without it being tainted by the prejudiced opinion of forum “experts”.
Another option is to keep the FlatCap on the StageLine and CD Player.
Then use the second HiCap on the 282 as well.
DG…
As I understand it, two Hicaps on a 282 should be carefully matched, so not one DR and one non DR. I tried a Hicap on a CD5x, which made it sound crazy, and a Flatcap was much better. I suspect the best result will be HCDR on the 282, HC on the Stageline and FC on the CD5x.
I will let you know were the spare HC will end.
Does someone has information how to connect the hc with the cd5x? I couldn’t find a clear answer on this.
Remove the link plug. Connect the upgrade socket to Hicap socket 4, band at CD player end. CD player mains lead still needs to be connected.
@james_n is soo good at explaining this that I won’t even try myself.
Signal straight to preamp from cd5x output socket I asume?
Yes, connect just as you would if using it without a Hicap.
From HC to HCDR on 282: yes better. More low more detail and rest/peace.
From Flatcap 2x to HC on the CD5X: hmmm not sure need more time tbh i did not hear a difference.
Need some more listening. Than I will swap it again and i will get back what I experienced.
