Naim plugs are only required on NACA5 due to its stiffness. Not needed on flexible cables. I have normal banana plugs on the phantoms and they are fine.
What a surprise seeing you here Mr Steel!
I have been using Kudos K1 cables for 3 weeks now, replacing Naim NACA5 on Kudos Titan 606, powered by 552DR/300DR suplied from CDS3/555DR.
I must say they are a revelation. Tight articulate bass, lovely mid and superbly detailed treble. So so sweet and I am hearing more detail on many recordings.
I also tried WH Phantoms but didnt get on with them as they were a slightly smoother version of the NACA5.
They are keepers and an absolute bargain.
Does anyone know the capacitance and the inductance of this cable?
Assuming you mean Kudos KS1; it looks similar to Chord types such as Odyssey.
Kudos (much like Chord) don’t publish any specs but its form & construction will result in ball park numbers around 60pF/m & 0.6uH/m.
It has 19 strands of silver-plated OFC insulated with FEP & a PVC outer jacket.
I also found another www thats says its 15AWG - (using AWG is something that Chord also use, odd for a Euro/metric country) 15AWG is 1.65mm/2
As a comparison Chord Odyssey is
12AWG = 3.31mm/2, 19 strand silver-plated OFC, PTFE insulation, silicon outer jacket @ 8mm OD…
My own test results for Odyssey are 56pF/m & 0.6uH/m
Hi all!
I received a few days ago my ks1 cables, which replaced chord epic twin in my system (cd5/sn2/kudos c20).
My first impression are:
- a much greater « boogie factor » than before
- tighter and deeper bass
- very detailed mids
- but shy treble with little expansion.
Am I the only one to have this feeling?
Should I go through a proper and lengthy burn in period?
Happy to have your thoughts!
Arnaud
Don’t bother about burn in, just enjoy your music
Thank you Debs, I certainly do !
But my point is more on that shy treble I’m experiencing.
Do you guys have the same sensation of having a (too) polite treble with Ks-1 cables?
The SBL tweeters sound wonderful here with KS-1
Perhaps the treble you have experienced before was forward, and it is this what you have gotten used to.
I’m thankful the KS-1 is what it is with excellent tonal deliverance, nothing worse than an over-bright cable foisting a shouty Scanspeak to fatigue the eardrums.
Folk have on occasion even criticised Kudos speakers [ such as C20 ] for being over-bright, so perhaps you only need to persevere with the music play for a while, and allow your ears to acclimatise (?)
Hi All,
My kudos needed a fair amount of burn-in period. Now that’s over and the Ks-1 sound now marvelous across the whole frequency spectrum. Great move in my opinion!
Just for fun, has anyone compared the Kudos Ks-1 cable with Super-Lumina cable? I’m amazed that some of you guys chose the Kudos cable in your rather high-end Naim system…
Very expensive cables may merely sound different, or perhaps better but with law of diminishing returns.
The KS-1 speaker cable performs exceedingly well between my 500 & SBLs, a noticeably improvement over NACA5, and the fact it costs a little less is admirable.
Fitting my KS-1 cable in last April, didn’t need any burning in at all, sounded right from the get-go. Haven’t giving it much thought since, i forget all about it because lets me get on and enjoy the music
Yup. Likely true of both speaker & interconnect cables, IMHO. There is an ‘difference’ which is discerned, with a ‘new’ cable - and is deemed to be ‘better’.
Who would say its worse, if they had spent say… £30 per metre on new cables…
Maybe its just the ‘newness’…?
YMMV as always…
£30 per meter is cheap at today’s prices…
When you bought Naim A4 for £1 per metre, £30 still seems a lot…
And - remembering that Linn K20 is essentially almost the same as Naim A4…
K20 seems to cost around £5 to £6-00 per meter, currently.
Conclusion is clear - IMO (YMMV, etc).
Linn K20 is the obvious value for money choice for Naim amps…
How is your Kudos terminated into your NAIM amp? Is it the NAIM connector ‘block’ or standard banana plugs? Thanks.
Standard banana plugs and they work just fine into NAP300DR.
