The Listening Room Reality
I could indeed include some transparent diffusers on the back-wall. Like those ones :
EZ-Pro-1D-Clear-Diffuser
All those changes aren’t planned before at least next spring.
Hi Peter,
I thought about repositioning the system lengthwise. Unfortunately, it is a bit complicated.
Repositioning the system lengthwise means completely blocking the left windows, which might be a problem.
It also means removing the diffusers from the current front wall. They glued…
Considering the amount of treatment I’ll use, asymmetry shouldn’t be a problem anymore, at least down to 55-60Hz.
Even now, it isn’t really one. I have a very focused stereo image. Left and right walls are treated with 20 cm GIK Bass Traps (plus the acoustic veil on the right side).
The changes I’m planning will include 40cm of OW-703 covering the entire left wall (including windows) and, on the right side, a wall made out of 30 cm of OW-703 acting as a room divider.
I’ll have another 30-35 cm of OW-703 covering the entire back wall (the windows).
It’ll really be a massive amount of OW-703!!
At that point, I’ll make some measurements. Depending on those measurements, I’ll add Artvonion Sub Bass Traps (they can hit the 37Hz - 60 Hz region).
If possible, I would like to avoid the AVAA20, not because of the price but because they are active devices.
You don’t know how right you are! I did a lot of fencing before succumbing to the attraction of mountaineering. :laughing:
Hi Thomas, my length firing proportion was also to allow bass waves to roll out into the length of your space and become less modal. You clearly need a project :grinning:
I have glued panels up on my walls with Gorilla glue and tbh honest making good isn’t to bad, filler/sandpaper and paint is all you need. In fact I’ve made good on my ceiling 4 times :crazy_face: Good luck with it Peter
Hi Thomas, are those quadratic based diffusers (?) in which case you might need to move your listening position slightly forward. I know you yourself state 2 metres, although literature also states no less than 1.5 metres, but this could of course be frequency dependant I guess, ie the further down the spectrum the more distance is needed…. Best Peter
I have to check if the current system position is really a problem. Especially considering the ~13 m3 of OW-703 fiberglass boards I’ll add.
You’re right diffusion isn’t the best thing to do in “small” rooms. I believe the distance depends on the type and amount of diffusion. 1 or 2 meters… it’s very subjective and based on psychoacoustics. The more the better.
https://www.ezacoustics.com/ez-pro/diffusion/ez-1d-clear-diffuser/
Very clever idea in clear perspex though Thomas :+1:t3:
Got the frames up this morning.
Canvases slot over them.
I can hear the difference already :roll_eyes:
Mark
Wow, that was quick Mark. What have you put inside and what difference are you hearing?ATB Peter
Sorry Peter, that was a bad attempt at humour :crazy_face:
There’s nothing in them at the moment, but I think I’ll go with foam … not sure yet what density I’ll need.
Mark
Check advanacoustics out Mark, they do different foam thicknesses 1, 2inches and so forth and are UK based. The white is very easy to cut to size with a knife :+1:t3:
Good luck Peter
PS. You can find measurements for the various products on their website also.
I will forward those pictures to the wife and suggest it for the windows of our extension and run a mile awaiting a response :smiley:
Excellent, thanks Peter … did you mean advanced acoustics?!
Mark
Yes sorry Mark :+1:t3:
No problem :grinning:
I like that they give the measurements and graphs, the lower density Acousti-Slab gives higher absorption in the midranges, looks like the one I’ll go for.
Thanks again,
Mark
Mark. This is what I had in mind although I haven’t used it
https://www.efoam.co.uk/index2.php?shape=Frectangle
Love your idea. The amount of paint is likely to determine how reflective the canvas is so be great to experiment with and with canvases removed just for the interest of we observers Best of luck with it and look forward to seeing the artwork from your daughter
Thomas this entire thread is very interesting and helpful. I have to admire your single-mindedness. Just wondering why you are using the fibreglass rather than the denser Rockwool or are you looking to allow some of the bass to pass through.
Although an American site and therefore in pounds per square foot the relativities are nevertheless valid: have you seen this
https://www.atsacoustics.com/page--Selecting-the-Right-Acoustic-Material--ac.html
Hello John, thanks, I did look at that site and a couple of others. In the end I went with the Advanced Acoustics foam … which was due to be delivered today but looks like it’ll be tomorrow now.
I’ll try to get REW setup at the weekend and measure before and after. It’s been almost a year since I last did it and the room has changed a bit since then.
Should really have done it before ordering the foam … not being very scientific :roll_eyes:
Edit: 5 minutes after posting this it turned up :slightly_smiling_face:
Mark
Well Mark, there is no doubt that cladding your back wall with those filled in canvasses, will reduce overall reverberation time in your listening space in mid to high frequencies :+1:t3: ATB Peter
PS. Tell your daughter to thin her paints please :wink:
