2.5% participation ![]()
Merely a visitor imagine if I’d bought one. ![]()
Black Oak, Satin not an option anymore.
Did flirt with the idea of white but James at TomTom said resell of white speakers is tough, which is a minor consideration as I tend to keep mine for a long time / life.
I think they look great and my Guru 12’s are white front with Fog sides / top and bottom.
Now the only decision is which Nait 50 environment they go into. Both fronted by 1210GR2’s and Denafrips Dacs for streaming. Just the CD varies with CDX2.2 in the house system and Denon DCD1700NE in the cabin.
Can’t go wrong with the N50 and Petite Classic Adam, just the perfect combination
I have 2 N50’s in different locations both with petite classics, in white and walnut
They do look very good indeed in this setup. Will you be replacing the ATC11 with the Neat Petites?
Hey @Bevo , I’m thinking I’ve made a mistake and they won’t have been ordered yet, I should go white shouldn’t I. They look great.
Pretty sure nothing will have been set in stone and now thinking the white is the way to go, why fight what you know is right.
No. The porting is an issue for me. The ATC remain. For now.
White finish goes really well with modern decor and light wall finishes etc. I was a bit unsure at the start but I really like them now
As a few members own two NN50, there’s around 1500 owners not present…worth a thought.
Look spot on.
A couple of paintings for back wall soon
Very nice, how do speaker pods compare with speaker stands?
How are you getting on with it @Jubeph
Not quite as good but quite OK , my other petite classic’s are on stands and very good so bit of a compromise here due to space etc - very happy though they sound pretty good
Order confirmed changed to white !
Great. Really I love it. But my main problem is to find the correct t combo dac streamer. What about an ND5XS2?
Hopefully satin white? White oak if it exists would be a bit odd looking.
