Mine was sealed with “Naim-Tape”
And for the first time I had real issues in opening the box. Was sealed very heavy.
Serial 534…
The brown protective outer packaging was sealed with paper tape and very easy to open
No - the other one - the vintage Box! Sealed with some Tape with fibers inside.
A bolt of lightning
Ah sorry, my main box was sealed with paper tape
That LED though ![]()
Lovely bit of kit ![]()
Listening to Tame Impala - Let it Happen… YEAH! Fantastic!
Coming from a 1993 Nait 2 (serviced) control detail boogie this is a triumph
Only had 3 hours ![]()
BTW it has a thermal cut off
How do you know?? ![]()
Er it shut down ………
Thats 5am
Another advantage of the Nait 50 - allowing the upgrade of a PowerLine. Certainly the Nait 2 cannot factor this in.
This thread really needs to be locked because my willpower continues to erode away at an alarming rate.
I’ll regret asking this, but any feedback on the quality of the headphone amp would also be insightful.
Not from me I’m afraid headphone use I go direct into the DAVE
Yes - thought the same. Nait 2 and Powerline wont fit.
To decrease your willpower a tiny bit.
ND555/52/135/SBL is way ahead… ![]()
Not really surprising for me - but with nait 50 (in my case) in a better positioned system… Hmmm.
Willpower go for it ![]()
No headphones here
7 hours in from the first power up of the Nait 50 and I’m still listening, I feel a 3am session that will take it to 12 hours.
Damn - need a second Powerline. If it always brings this bass weight (e.g. on 555PS where it was delivered with), I do need another one
