Still can’t understand the fuss about this.
My new NAIT is putting out a clear white light when switched on, but not remotely extreme or off-putting.
Mastermind game?
HBTQ Edition
Mine makes Sirius look dull
Lovely job and balances nicely.
That denser white looks great, nice job @anon17748768 much nicer to look at.
How easy are they to fit? Do they just push on & how far out do they protrude?
Sorry for all the questions
Still waiting for mine to arrive, booked in to pick up Fri 21st from dealer as long as it’s arrived
Thanks, the denser white (501-7132) looks the better,
It just pushes on - snug fit - it does protrude circa 3mm beyond the LED. I have several ‘spares’ so will practice trimming the length down to suit using scissors/sharp knife/stanley knife/scalpel…, having said that it looks OK as is (to me).
Good luck
I have just ordered today 2 X 4 m NAC A05 to connect my L Eatons to my Nait50 and therefore my NAP 200dr
I am looking forward to hearing an improvement in comparison with my budget QED XT 40I or Chord Rumour !
Thanks, just keep those sharp implements away from that amp
Kitchen worktop & chopping board job…
wouldn’t want to scratch the amp, would have to buy another one…there’s a thought
Don’t cut with scissors it’ll go like a beak.
Put one on a thin dowel or pencil etc then roll a scalpel round and it will be flat.
makes good sense, will try that, thanks
They’re absolute winners as a complimentary pairing
Thanks, I am a little overwhelmed how good the Nait 50 is, and equally overwhelmed how good the EverSolo streamer is - just fitted a 2TB ‘SSD’ card to it so I can play with copying music over to it.
Will get the ES Master edition next month to compare and maybe another ‘50…its’ all good fun
I cut mine with scissors, easy.
They are just tiny rubber caps, push on pull off.
Just cut some down trying a few different methods…got a good one !
I have absolutely 0% need for a Nait 50. But am weakening every day!
Super looking system
That’s because you live in ‘bright’on. People are used to a lot of light there. Ever been lost in Yorkshire by night? Doesn’t get darker than that.
The setting for ‘An American Werewolf In London’?
Cracking film, also did wonders for London Underground
