Brilliant or bollocks?
Is it recommended to blind test it before buying?
I would like to order one please!
Can someone tell me which cables I need to hook this up to my Flatcap 2X?
As it comes in a single container, I am thinking it must be part of the Uniti range.
Shouldn’t it be ‘Sanitiser’?
My thoughts exactly.
I can be either - the z is predominantly found in North America whereas in the UK the s is more common.
Apparently it needs a NAPSC to glow in the dark, and there is an ongoing debate regarding whether to upgrade to 2 x HiCap or a SuperCap.
But what is it’s purpose? Do we need to use it if our Naim gear isn’t double jabbed?
Conection cleaner?
The hand sanitiser creates a sonic barrier from your hands to your remote keeping and EMF/EMI/MFI from your music devices. Don’t knock it until you’ve tried it.
You can also use it to clean your ear out
OK, the second one may not be true.
