Things I’ve learned in 2025
It feels as if it’s been a long year, but I did learn a number of interesting, or not, things about my system;
  1. My current system is probably a lot better than I thought it was at the beginning of the year.
  2. There is probably no such thing as a zero sum upgrade, only change for changes sake.
  3. A good deal is rarely the bargain it might appear to be.
  4. If you want a step change upgrade be prepared to completely change your system.
  5. Audition, audition, audition.
Now looking back, that all seems completely obvious doesn’t it? All I can say is that you’ll know you have a great dealer if they emphasise any, preferably all, of the above points when you approach them saying ‘I’m thinking about a change’ :innocent:.
ATB, J
Noted and did exactly that @Osiris :wink:
I found out what the definition was of a Melton Mowbray Pork Pie.
Burn-in is a real bugger isn’t it?
.sjb
Isn’t it just :innocent:.
ATB and Happy New Year!
