…….how do I amend my profile?
Click your profile image in the header bar top right, select Preferences from the menu that appears (3rd icon on top row, head & shoulders icon) then go to Preferences where you can apply edits.
On an iPhone or similar tap the profile image top right, then tap the human symbol and select Preferences from the subsequent menu. Finally select Profile from the drop-down list on the right.
Thanks guys. Strangely you can’t get the preferences option when you go in through Discourse Hub. All fixed now though.
Are you updating your profile for the Solstice TT?
Mr B you know full well that I’m not going down that road!
Of course Mr Milne
