Whenever I play a Tidal track which is only AAC instead of FLAC it always seems to display the sample rate as 96 kb/s. (I say always, but as I haven’t come across a huge number of these tracks so far I’m basing this assumption on a low sample!)
The quality certainly doesn’t sound that bad so I’m thinking this is just an incorrect display.
I’ve had a look and those particular albums are being delivered in 96kbit AAC, so the app is correct. AAC is a good codec for using the bandwidth available wisely when dealing with low data rates, unlike MP3.
Thanks for the reply. I wasn’t meaning to take up the time of Naim Software personnel but many thanks for taking the time to check this out.
The tracks do sound quite listenable -through a Muso anyway - although I’m sure a full FLAC file would be better. Good to know the app is functioning correctly as well.
