Is anyone else having issues with Tidal playing music through the Naim app?
The app logs me in and I can browse fine, I can play music through my other phones and can happily stream via AirPlay but it will not play anything anymore via the app.
I’ve logged in/out many times … tried changing the stream quality from high to normal … even reinstalled the app … nothing … tried on different phones and no joy either.
Fed up with the issues I have with this … wanting to sell
Ok the other question I have is about how your Star is connected to your router. Is it WiFi or ethernet cable? If WiFi then it would be worth buying a cheap long cat5e ethernet cable and temporarily connect it that way.
Best
I’m almost out of ideas. One other thing which sometimes fixes a problem even though everything else works and you can’t see why it is relevant is to restart your router.
If you haven’t tried that then turn the router and the Star off, restart the router and once it has settled, restart your Star. You will probably want to restart your NAS too.
Best
