tbh I was very rarely using the service… I just found it annoying the one time I try to I waste half an hour and still don’t get anywhere. The ‘app’ says files added to the queue. The NDX says ‘stopped. press play to continue’. You do and it then says something like error with the format and skips all of the files. It’s also a pain getting back to ‘normal’ operation. I found the only way was reboot the tablet and the NDX!
FWIW - I have had a NDX for about 12 months with TIDAL via the NAIM App and it has been working without any issues. Prior to the NDX I used Tidal with my ND5 XS. I also use TIDAL through their app with my MAC Air and iPhone without experiencing any issues. There were some issues prior to that with music dropping but that issue has not raised its head in a very long time.
Perhaps I have jinxed myself by chiming in but I have had a very good experience with TIDAL and find I get my monies worth for the monthly subscription fee.
I have the same problem. Via chrome cast it does work, however with the native integration it does not work anymore. This used to work great. I could not find a solution on the forum. Any tips/tricks?
Have you been following the ‘other’ thread on this topic? There’s a lot more info and thoughts there. No solutions but at least a better explanation etc… of what the current ideas are on this issue.
