When using the Tidal App on a samsung android phone i try to switch the sound to my muso qb but the app can’t find it. I have the naim app installed and that works fine, so the problem seems to be withthe tidal app??
Spotify works fine but of course the sound quality is worse so Tidal would be preferable.
Anypne had this problem with the Tidal app?
On android airplay is not supported and chromecast and connect is not supported on the first generation streamers.
