How can I get rid of Tidal Connect from my Uniti Star and Mu-so 2? I’ve never been a Tidal subscriber nor want to be (I use Qobuz) and I wonder if the presence of Tidal Connect is affecting the performance of Roon in my system.
In the Focal Naim app, select the device, then Settings/Streaming Services/Tidal/Disable.
As to whether it affects Roon, I have no idea as I don’t use Roon.
Yes, I’ve already done this in the past and TIDAL is turned off. However, if I open my Network on my desktop Windows PC, I can see my two NAIM units and if I open Properties it takes me to a NAIM Configuration screen. If I choose the Configuration tab and scroll down to Tidal, it shows (correctly) “Not Logged In”. If I scroll down further I come to “Tidal Connect”, where it states Service Status “Running” with a green tick alongside the status box. I can’t see any way of turning it off. Do I need this? Is it really necessary or is it just a way for Tidal to find new customers? If I don’t need it I’d really like to turn it off.
