Not sure why Naim hasn’t said anything yet. The streaming board just released their update about a month ago, so now it’s up to the streaming companies to make their personalized updates. So it’s certainly capable of playing Tidal Max once it’s gets the firmware update.
The streaming board also mentioned usb direct connection from a computer and Spotify updates. So maybe if Spotify ever released lossless, it will already be capable. But I guess up Naim to decide what they implement.
One thing I have noticed is if you use the Windows Tidal app, you can stream via Chromecast (mobile devices default to Tidal connect). When a 24bit Flac is available it does play at Max, otherwise it defaults to 16bit as usual.
The Wiim (only a cheapo mini) is now working perfectly into my NDX via an optical cable, I did have some initial drop out problems, but I believe that some of this was most probably user error.
I am actually getting used to this now - I select the correct input on the NDX (one of the digital inputs dedicated and re-named Wiim on the screen) and from there toggle between Spotify and Tidal on an iPad enabling me to get the best quality stream for my chosen track.
I am considering an upgrade to a Wiim Pro ( last of the big spenders is me! ) as a good friend has had a very good experience over and above a Wiim mini.
Thanks Mr. Happy that’s very helpful. I might just buy a Pro myself then as it’s a lot cheaper than an expensive naim upgrade but using my ND5XS still retaining the main sound. Best of both worlds for a couple of hundred quid!
For the record WiiM are developing a new device called the WiiM Ultra which will have a screen, aluminium case and USB audio output. It should be available Q2 2024
This is the bit I don’t get. Just say what is happening. Even if it is second half of the year at least there is a target people can work with, rather than this total lack of communication.
I think I will switch to Qobuz and will see if I will switch back to Tidal after the issue has been solved. I did an extensive comparison over the last few weeks and in my opintion 24-bit Qubuz sounds a lot better than 16-bit Tidal on my NSS 333. The only reason for switching back in the future might be the subscription costs.
I have both and have been waiting to go to Tidal only for months now. The organisation of things in Qobuz is terrible. When querying for things it just returns a jumble of unsorted stuff.
And the Tidal connect feature is pretty cool for providing everything the Naim app does not.
So living in this limbo of double subs till Naim supports hi res Tidal.
But if Spotify eventually does release lossless, are we going to have to wait over 6 mo for Naim to upgrade their Connect feature to handle it? The streaming board did mention that their next est firmware did have some Spotify updates. And heard some other Streamers had Spotify lossless already ready to go when Spotify finally was ready to release it.
