Obrok
October 2, 2023, 7:56am
1
Hi,
I have the Tidal HiFi Plus - when playing on my mobile, the Tidal App shows “Flac”.
When I start streaming to my Naim Nova, it changes to “High” and the Naim app shows FLAC 44.1kHz 16-bit.
The WiFi streaming quality in Tidal app is set to “Max”.
I’ve reinstalled both apps, logged in and out of Tidal in the Naim app.
Nova’s software is up to date.
Any ideas?
Thanks!
IainO
October 2, 2023, 8:02am
2
naim need to release new firmware to support max (above 16/44.1).
As do many other vendors.
Tidal support won’t say much other than Tidal Connect will be available to use with max “later this year”.
It might be early 2024 until max is fully supported via naim app and Connect, but we will have to wait and see.
Long thread here
Tidal now seems to have left the “Master quality” and replaced it with “Max” see the picture from my ios app. When I tried to stream via Tidal Connect, the stream was switched over to “High”, which should correspond to 16/44.1.
Via the naim app, it is also not possible to get a higher resolution than 16/44.1, as it is only possible to select “Hifi” as the highest quality, which corresponds to today’s “High”
Have managed to stream Max quality wired from my iphone to an older Chord Mojo.
Does a…
Obrok
October 2, 2023, 8:17am
3
THANKS, I was going mad with this.
So I’m paying for the HiFi Plus option but cannot really listen to the Max versions… what a bummer!!!
IainO
October 2, 2023, 8:19am
4
Workaround needed for the moment, yes.
We should be clear the mess is no fault of naim, Tidal released the tier with only support on Tidal clients really.
The SQ via workaround makes it more frustrating, bet it’s going to sound great when part of native device support.
There’s still a lot of MQA being used, which of course naim devices don’t support anyway.
Obrok
October 2, 2023, 12:59pm
5
I still cannot get over it. These guys are a joke, really…
https://support.tidal.com/hc/en-us/articles/360004565898-TIDAL-Connect
HiRes FLAC is currently not supported through TIDAL Connect. Support will be added later in 2023 .
IainO
October 2, 2023, 6:31pm
6
Yes, nothing has changed since Max was announced.
We had to spend 50 quid sorting it out!!!
system
Closed
December 1, 2023, 6:31pm
7
