Hi
When using the tidal input on my nac 272 it plays at cd quality flac.
Does the NAC 272 not support MQA/hi res when playing this way? or am i restricted to cd quality only?
Any information gratefully received.
Hi
No Naim product supports MQA.
luckily can play mqa via usb dac then in to analogue section of the pre amp.
using 3.5mm to rca.
This is the second time in 6 days that you have raised a thread on the same subject.
Might be appropriate to ask @Richard.Dane to merge the threads.
Second, @Suedkiez posted an answer to your earlier thread; maybe you didn’t see the response, peps here do try to comprehensively answer original questions.
Third, use of the search function subject MQA provides 50+ results - a few of these will point you in the right direction.
Edit - thanks yet again to @Naim.Marketing for “aiding” the search function!
Probably best to just close this - the OP has their answer now, here and on their earlier thread…
