Hello. I have a fully updated Unitiqute and I can’t get Tidal to play at 96 kHz or 192 kHz; everything plays at 44 kHz. I’ve tried everything and there’s no way to fix it. Other people have tried it with their accounts and it works perfectly. Tidal on my phone plays everything perfectly, the problem only occurs when I use the Focal & Naim app. I’ve tried everything you’ve suggested here and nothing works. Let’s see if anyone can come up with a solution.
If you mean Tidal Max, then it’s not supported on a Unitiqute.
As I was saying, it has been updated to work with Tidal Max. In fact, I tested it with someone else’s phone and their Tidal account, and it played up to 142 Kbps without any problems.
