Tidal seems to have gone into shuffle mode on Naim App. i know somebody had this problem before ad cured it but I can’t seem to find the icons he found. Is there a simple on/off shuffle icon I’m missing?
Yes, left hand side towards the bottom is the shuffle thing.
My Naim app decides to play shuffle in Spotify or Qobuz.
Personally I’d disable shuffle if I could.
Many thanks.
