I can stream Tidal at 24/96 to my iPhone via its Tidal app, but when I play the same song on my NSC 222 either through Tidal on the Naim app or via Tidal Direct to my 222, all I get is 16/44. Similarly, my MuSo QB Gen 1 will not go above 16/44. Every setting I can find for Tidal quality is set to Max or HiFi. Thoughts?
Check the dozens of other threads on this topic. In short we’re waiting on a firmware update from Naim to enable hi res flac on Tidal
Thanks. I should have searched harder.
