Tidal streaming on my Atom is breaking up so is unusable, streaming internet radio is OK.
Any ideas please.
Have you tried turning it off, unplugging from the wall, waiting a couple of minutes and turning on again. I’m in the U.K. and Tidal is working fine.
Yes I tried that
Having said it’s ok, mine’s just dropped out, so it must be a Tidal thing.
Yes, there is an issue affecting Tidal CDN infrastructure … its on the down detectors
Having already layed off 10% of staff, Jack Dorsey’s brilliant management skillz, means more jobs are going very soon, a leaked memo states (see Billboard Magazine).
Remember, “pivot” in internet business parlance, actually means “panic”. ![]()
I don’t know how much of their technical resource they outsource… I suspect a sizable part. Clearly CDNs are global caches run by major third party organisations.
Indeed, and it may only be purely coincidental.
Time will tell.
