Time to experiment with cables
Have you optimised your room, both in terms of speaker and listening positions and acoustic performance (e.g. early reflections)?
as much as I’m prepared to do.
This hobby is a fickle mistress. In all the years I’ve been listening the one lesson I’ve learned is that you’ll never know until you try. I’ve found some real improvements over time but often by shear chance. If you are a natural ‘experimenter’ and you have time then try as much stuff as you can. Sometimes you’ll go round in a big circle and sometimes you won’t. I’d just enjoy the ride.:+1:
I can’t comment on what might or might not work with NC stuff, but I’ve tried various Chord interconnects and mains wires with my old classic system and each every time I’ve come back to Naim’s own wires, to these old ears the Naim wires just have a more, dare I say, rich and organic sound. This includes upgrading to Superlumina for NDX2>552, and hi-cap>552 on my vinyl configuration. Similarly Naim Powerlines seem perfect across the system including on my Vertere PSU. The exception to this is speaker cable where I’ve never found an improvement on Chord Odyssey. With regard to Chord interconnects in particular I found the Signature very bright, Sarum less so but it still didn’t have the engagement that came with the Superlumina.
However, it’s all subjective, you will of course receive a myriad of very well informed opinions, but the only way to arrive at a conclusion is to ask a Naim dealer (assume you’re in UK?) if you can try some alternatives.
My thanks to @thinkstuff for starting this thread. A couple of months ago I was just about to start tinkering with interconnects between 332/350 and 222/250. My (excellent) dealer was organising some Tellurium Q silver and black cables for me to try. Then I got a 3 month notice of redundancy letter from my employer (out of the blue, after 28years of service and bringing £ms of outside funding into the organisation). :face_with_raised_eyebrow: I wasn’t very pleased. So this all went on hold.
I thankfully have secured a new role so probably next year I may revisit this.
In the meantime I will follow this thread with interest.
Maybe something like the Nordost Heimdall XLR cable between NSC222 Pre and power would be a start. Currently using a 3m long chord shawline between my photo stage and pre, I dont need a 3m cable anymore as my set up has changed since I bought it, may look at something “better” there as well.
I did try various cables on my Olive stuff back then, also later on with Classic stuff.
Nordost were the worst by a mile, far too expensive, sterile and no life - not for me.
Chord were hifi, in the long run I went back to Naim cables.
Now I run Kudos KS1 and standard cables for my Naim and Rega, can’t bother anymore with cable changes.
What Nordost XLRs were you using? My only experience is with the Frey 2 and Tyr 2 which are high end. The experience has been superb.
@ thinkstuff I’ll throw out my opinion .. Upgrade power cables with Shunyata Theta if it’s in the budget ,a Shunyata Delta X power distributor .. Start there You’ll be very surprised!
Installed the Sarum T Speaker Cables in my Main System yesterday and left them dis-connected.
Switched off the Subwoofer and played my Tidal Test Playlist whilst doubling up on a couple of tracks to fully dial my ears into the sound quality/presentation using the original Signature Reference Speaker Cables.
Tidal Test Playlist Tracks Used Were:
The Cure - A Forest
Daft Punk - Giorgio by Moroder
The Beatles - Come Together (2019 Mix)
Amy Winehouse - Back To Black
Amy Winehouse - Rehab
Sting - Brand New Day (My Songs Version)
Sting - Desert Rose (My Songs Version)
The Rolling Stones - Terrifying (2009 Remaster)
The Rolling Stones - Mixed Emotions (2009 Remaster)
Dire Straits - Brothers In Arms
Dire Straits - Sultans Of Swing
Seal - Crazy
Seal – Killer
Adele – Rolling in the Deep
Adele – Someone Like You
KD Lang/Roy Orbison – Crying (2010 Remaster)
Underworld - Born Slippy (Nuxx)
David Guttea featuring Kid Cudi - Memories Extended Version
Safri Duo - Samb-Adagio
Then un-plugged the old cables and plugged in the new cables (5 minute job) and re-ran the playlist and again doubling up on a few tracks.
There was a modest improvement to the detail and clarity of the treble and mids and the bass was more defined and tighter. However, the biggest improvement was that the overall sound presentation was now a little bit smoother, a little bit warmer and more analogue sounding (for a digital source), I thought the vocals and instruments sounded a little more natural and life like which I preferred, so I’m very happy with the cable upgrade.
This morning, I switched the Subwoofer back on and re-ran the playlist again with the track double ups and I’m now very impressed with the sound quality and sound presentation of the system, the Subwoofer, just lifts the whole sound up a notch or two.
Cable enhancements are the icing on the cake for a system to get closer to it’s optimum sound and adding a subwoofer, is the cherry on the top, getting the system to sound just that little bit better again.
When I had my Nac 282 , Nap 250 DR system, I was very impressed with the improvement with Vertere Redlines. More engaging and more detail, just overall much more engaging than the with Naim cables.
Now I have a different system altogether and have connected my DAC and integrated amp with Nordost Tyr2 XLR. Fantastic cable that really opens up the soundstage and instrument separation. Before that i had the AQ Earth, which are very good with voices but have more constricted space.
I did try the Chord Signature and found that they really open up the sound stage. But this depth and instrument separation can sound restrained, because instruments sound less in your face. Really a matter of system synergy. The Tyr2 achieves that also but sounds less restrained in my current system.
However, before you think of interconnects, you may consider powersupply. May bring more benefit with less investment.
Installed and tested the Chord Signature Reference Speaker Cables from my Main System, into my Second System this morning, replacing the Chord Epic Speaker Cables.
Used the same approach as that I took installing the Sarum T’s in my Main System and Wow, what a big improvement in sound quality and sound presentation.
Much more clarity and detail in the treble and mids and much better definition and control of the bass. The most significant improvement is the sound presentation, more forward, more attack and much more boogie factor than before, so much more engaging and musical.
I knew from my experience with Chord Interconnects, that the sweet spot in the Chord ranges was the Signature, but from my experience now, this is also the case for speaker cables.
If I had not of upgraded my Main System cables, I would of never of changed my Second System cables, I’m so pleased I did, what a great sound quality and sound presentation improvement.
In the end I found some ex dem NAP 350’s online that arrived yesterday and will hold of the wires till its been here a bit longer. The 350 are certainly very different to the 250 they replaced, in a good way!
I think that is a very good upgrade approach, maximise the electronics and speakers and then get some further, smaller improvements with cables.
Good luck with your 350’s, Im sure they will be a great improvement based on forum feedback.
