Looking to solve an issue I’ve had with Qobuz and the Naim App the last few months. Qobuz has become painfully slow, I select the album I want to hear and it can take 15-20 seconds for the track listings to appear. Force quitting the App does not help, when I replaced my iPad recently the response time improved briefly only to slow down again.
Ok that’s a small number and very odd. I asked because in the past the Naim app was close to unusable on Android with ~2000 Qobuz favorite albums, but that became better with app updates over the past 6 months or so. But obviously most likely unrelated to the issue you are now seeing
This may be obvious but on your ipad if you double click the large start button just below the screen……all open apps appear. If you have a large number open, just swipe them up and away to close……is it now faster on Qobuz.
No. I’ve been using a Google Mesh for a few years now.
ND555, UnitiCore, EE switch, Cord Ethernet cables hard wired. Cisco switch at the distribution hub in basement.
OK, logout/login. First album I opened in Qobuz the track list immediately appeared. Second album the track list took 5 seconds. Third album took 20 seconds. Sigh.
Power cycled the ND555 and EE switch. Force quit the Naim App and now tracks are loading instantly. Things must get clogged up…I’ll know what to do next time I see this issue.
Can’t hurt to try, but actually iOS is quite smart in managing resource consumption of background apps. If an app wakes itself up too often in the background, it drains battery but should not have much performance impact unless the app is very misbehaving. If an app does too many wakeups, you can take away its “background refresh” rights.
