Titan Audio Cable Lifts
…or just buy the Titan ones like I did? I paid about £28 for 4 which is only £7 each! You could try and make some, but at this price and the fact they made a definite difference I would go down that route. These Titan ones sit on the very edges of the feet like a knife edge and I assume this is a key design feature.
Hi Henryski. I have access to a laser cutter which makes them easy to make! They are made from clear acrylic.
Steve2
