Asking this questions to get answers once and for all…
Everyone switches on and off with the device on,.but no one knows if it can cause problems in the long run or not.
Also take a USB-cable,.what applies to it.?
Many people today have a USB-cable between their Streamer and DAC,.
what should be done there,turn off the device or not.?
ISP’s advise not to constantly power off as it logs the event as a line fault and that reduces line bandwidth (speed) to compensate for a period of no potential line faults.
Unplugging ethernet cable(s) does not harm the item being disconnected.
My only concern with constant ethernet cable in’s & out’s is the degradation of the electrical contacts & the plug and port click-lock mechanism.
Hi @Peder … correct, my logic is that if it was advisable, then the various network device mnfts would advise us all to switch off.
Plus with switches they need to be powered on to ‘learn’ the connections as they are added.
With USB, I would read the manual to see if they advise on this, but generally its OK to plug/unplug a live USB.
But as I said in my 1st post, constant cable plug in’s & out’s is the degradation, it will eventually wear out a contact or break something
I’m flattered, but I think it’s Simon you want if you’re looking for an expert!
Having said that, my understanding is that Ethernet cables are ‘hot swappable’ and nothing needs to be powered down. I certainly never bother to power down a switch in any situation including connecting or disconnecting Ethernet cables, and I can’t see why the LAN ports on a router would be any different.
USB cables I would also treat as hot swappable as long I’m sure there is no critical data transfer such as a backup in progress or a drive that needs a proper shutdown procedure, especially if the USB is supplying power.
Thanks to everyone who replied in the thread,.it’s much appreciated.
Although you can take certain things for granted,.I always want to know, so I do the right thing and don’t harm anything in the long run.
Thank you all so much for your responses…
I’m surprised you haven’t looked into whether order of switching everything on and order of connecting ethernet cables affects sound quality… (Tongue firmly in cheek.)
