I start to worry, when you can ID a cart from a picture like that…
(the picture was a quick grab from the webz… )
There might be a problem with model numbers or names…
…but…
The III or IIIs was and would be a very poor match/or disaster with low compliance MCs. I would go so far as to say this is not really contentious.
Oops…sorry for not reading the later posts.
What about a used Jelco 750 or 850 more affordable and would look ‘right’ on the SP10.
@jlewis - Lols. I was mixing up my Series 5’s and 3’s… And was there a Series 4 in there too…? Which was a cheaper version of the 5…?
I think that I was thinking the 3 was the 4… if that makes any sense…
No… Oh Well…
Sorry for jumping the gun…I had a IIIs with the lowest mass highest mass MM ?ADC ZLM 3?..just about worked, but otherwise virtually useless.
@jlewis - You’re fine. Interwebz… innit.
I admired SME’s when I couldn’t afford them. But when I could, I bought a Linn Ittok… which I still have & use…
I recall the ADC XLM - and the Webz tells me there was a ZLM, too.
