Hi everyone, I would like to buy a valve preamp without spending too much to combine occasionally with my 300dr. I currently use the 252/scdr, everything is wonderful, but I want to try which one would be the best for Naim. I await your opinions, do you recommend?
I used a valve pre with my 300DR up until recently, a Manley Labs Neo-Classic 300B. An amazing pre with an addictive, want-to-keep-on-listening midrange, solid build and reference-level headphone stage. The stock valves are not great, however and it responds very well to rolling your own which is vital in getting the best out of it so put aside 20% + of the budget to getting some good NOS valves and something like Sophia Electric or Western Electric for the 300Bs.
Now as for whether the 300DR mates well electrically with a valve pre, while I didn’t have any real issues I did read that bass can be limited when using a valve pre with a solid state amp. The combo produced great bass for me but I did notice when I swapped the Manley for my solid-state Esoteric pre recently the bass slam, impact and depth improved dramatically. Now is this because the 300Dr preferred being paired with a solid state pre or is my Esoteric simply that much better? Unclear. Perhaps a valve pre on the level of my Esoteric would produce bass on a similar level but without having one on hand it’s impossible to know.
Anyhoo, caveat aside I highly recommend the Manley.
Esoteric Grandioso C1X Solo. I never used a NAC 252 as I added the 300 DR long after getting the Manley in the first place. I know someone who has a 252/250 system and while it’s not a 1-to-1 comparison the Manley is a lot more musical and liquid sounding.
A couple of weeks ago I plugged in my EAR834 line stage, which i usually use in my nearfield system; thoroughly enjoyed it. But, it has no remote control, and for playlists I feel one is needed.
I owned an EAR868 for many years, which I also thought was good; but, a friend was selling his Modwright LS36.5 for what I thought was a rather good price. I am enjoying this more, although my system has changed so not a true comparison, not to mention the haziness of audio memory.
The 36.5 has AV bypass, when the amp is turned off. The sound quality is excellent, and the 36.5 / 300DR / SBL combo is pretty addictive.
