Turntable
I have a NAIM Muso Qb 2474 and I want to buy a turntable for vinyl. Any recommendations? I’m looking for super easy connectivity, so probably direct a cable link.
Thanks!
Guy
Something from Rega or Project should do the job. Make sure it is one of the models which has a built in phono stage (eg Rega Planar 1 Plus).
You’ll just need a 2xRCA to 3.5mm stereo cable to link the turntable to the Muso and you should be good to go.
Try a Forum search for ‘turntable for muso’ and you’ll find everything you need.
