quick question , can a uniserve be directly conected in a uniti2 or is it only UPnP? Still learning cheers
Yes the unitiserve has a digital output that you connect to the uniti 2 input. I have a cable between mine but i think there is also a fibre option if required
thank you
You can use a coaxial digital cable to connect the Unitiserve to the Uniti. Given that both devices really need a network cable for their full range of functions, it’s debatable whether there’s really any point in doing this. Also you would then browse and play music through the N-Serve app but switch to the Naim app for input selection and volume control.
