I am keen to hook up my turntable to a better amp as it sounds ok but not great through the Uniti 2 and I have to turn the volume up considerably more than if I were streaming / playing cds.
Can I run my Uniti 2 through a Supernait 3 as an input? This would only be temporary until I buy a new streamer. I am more concerned about the vinyl playback at the moment.
Appreciate any advice including any hard truths if this not a good plan.
Bear in mind you will still have to turn the volume up more when playing CDs or streaming. You can adjust the input trims in settings to mitigate this but phono tends to need more volume to sound as loud whatever amp you use.
If you intend to move to a 2 box system such as NDX/Supernait it makes sense to get the Supernait now, but as Nigel suggests above, if you think you will end up with a separates system eventually you could add a power amp instead, such as a 200 or 250, which will not become redundant later.
For me it’s always worth having an endgame in mind so that your purchases take you towards it without wasting money on boxes that you later find don’t fit in with your plans.
Yes that’s my intention to get a Naim streamer. As I mentioned I am keen to see if I can get more out of my turntable with the Supernait now and add the streamer later when I have the dosh. My CDs are pretty redundant now so streaming and vinyl end game for me. Cheers.
Should be getting SN3 this week. Do you think running my MM turntable through my Stageline and then into the amp would see any greater benefit from connecting it straight into the SN3? Thanks.
