Hi! Is there no way to connect naim uniti to a dac or preamp??
You could connect it to a preamp using the line out. It has no digital out so you can’t use a dac.
In the manual says “the line output is intended to be connected to a recording device” but you mean I can connect it direct to a preamp? Is it
Okey, is it a good signal for the preamp or are there limitations?
