I am also using Asset and that seems to have the same issue as Universal Media (i.e. I cannot see it from my other computer).
Then it is either that computer blocking communication or its your network config.
Ok. I have checked this and they are on the same subnet.
IPv4 Address. . . . . . . . . . . : 192.168.1.17
Subnet Mask . . . . . . . . . . . : 255.255.255.0
The last “17” is different on my Mac. Also I have pinged each machine from the other one and it looks like packets are getting received. (I don’t really understand networking but I think this makes sense)
>ping 192.168.1.19
Pinging 192.168.1.19 with 32 bytes of data:
Reply from 192.168.1.19: bytes=32 time=2ms TTL=64
Reply from 192.168.1.19: bytes=32 time=3ms TTL=64
Reply from 192.168.1.19: bytes=32 time=80ms TTL=64
Reply from 192.168.1.19: bytes=32 time=100ms TTL=64
I now need to investigate the other things you have mentioned…
I have a Sagemcom Fast 5364 router. From some forums it seems that I cannot turn off multicast. Though I am not sure how to check that for sure.
