Hi,
I m in a temporary situation far from my house. I’m listening only digital music from ndac with external psu. I would like to move my dac to my country and listen from a streamer. Uniti atom he could be enough in a 282+hcdr psu or will it be overexposed?
That’s not an ideal setup as you will be using two preamps. Maybe direct into the power amp would be worth trying, unless you need analogue inputs for other sources?
The Atom HE is the new kid on the block, so of course it can do no wrong in the eyes of the forum right now. Still, it is Naim’s entry level product, so I think you should adjust your expectations accordingly.
