Hi Naim community,
I’ve just received my first uniti atom and a pair of acoustic energy 500 speakers and am over the moon. However…a couple of questions as this is my first foray into the Naim uniti line…:
My power socket on the rear of the atom is a little bit wobbly and the power cable comes out very easily and if I move the atom a bit too reposition it can cut power and you get that horrible small crackling noise before you make the connection properly. It’s this normal? Is the power cable and the socket supposed to be loose and have some wobble? All original parts supplied with the unit.
Secondly, the proximity sensor is supposed to wake the atom up when in standby mode, yet it doesn’t, at all. I know that it works because I get the additional detail on the track in listening to when I get close, so it knows I’m there while it’s running. Am I missing a trick here, are the two things related?
Absolutely love it and the sound it produces, but am concerned about the power socket and a little sad that the proximity wake function doesn’t seem to work. Any help and advice is greatly appreciated - have tried factory reset, have checked the connection with the European plug also provided and get the same loose feeling, have tried all options and settings for the sensor.
Thanks to you all in advance!!
J
