I’ve only just noticed on the back of my Uniti Atom - “WARNING - do not replace supplied loudspeaker plugs with individual 4mm plugs”
Whoops.
What are the dire consequences of using individual 4mm plugs?
Whoops.
Err… nothing. But don’t tell anyone.
Elf n Safe Tea…
If you’re dumber than a post, the EU is concerned that you might put the banana cables in a Schuko socket. Do not do that.
Hahaha! Right you are ‘squire! I’ll see if the greengrocer’s got some EU regulation bananas…
Look at your own governments please.
