Uniti Atom- volume compensation
Hi! Will Naim planning add to Uniti Atom posability set up volume level compensation for different inputs?
It’s a perfect device but i have big problem when change inputs. HDMI connected to TV my normal listening volume level is 40 but Spotify connect or Qobuz connect listening level is 15.
So every time when I change input or after watching tv I must remember and check volume level. Otherwise
music start playing too loud. It’s very uncomfortable.
Many amplifiers has volume level compensation for inputs. Please add this simply setting in software for Atom
The Atom already has this - there are level trims for each input.
Go to Settings in the app, select your source and then adjust/trim the volume.
There is input trimming,go to system settings inputs and select one you need to alter
The input trim settings are available on the HDMI input you are using, but not on Spotify or Qobuz. You may want to try increasing the level on the HDMI input so that the volume control will be set lower when you switch to the streaming inputs.
Thanks everyone. I found it. ;)))
