Emerging from a lengthy surgical recovery, I’m catching up on entering downloads into my Uniti Core. After searching this forum, I need a reminder on the accepted artwork protocol. Is the proper file name “cover.jpg” or “folder.jpg?”
Either works just fine.
If you’re using the Naim app for metadata editing, you can upload your own artwork for each album (via the app), which will create the correct filename as well. If you’re fixing missing artwork for downloaded albums, you can use your favourite metadata editor (I use MP3tag on both Windows and Mac, and rate it highly), which will embed the artwork into the files for you.
Thanks, JonoB.
I think folder.jpg is the most “universal”
Yes. I found a few months ago that cover.jpg no longer worked. But folder.jpg does.
