Uniti core cd listing failure
Hi all
I have owned a NAIM Uniti core for about 4 years now and apart from an odd glitch it has performed well. It is attached to a Classic system by NAIM DAC.
I have ripped over 500 CDs, in FLAC, to a Samsung 840 evo SSD and enjoyed it. Until now.
For some reason I can no longer bring up the list of CDs I’ve ripped and it will no longer rip CDs. I can bring up a list of my Playlists and it will play those but when I select the “albums” heading it states “no results”. I can no longer bring up the albums by choosing composers, favourites, newest or other options.
I have searched for software/firmware updates and am at the latest. I deleted the operating app a couple of times and re-downloaded that as well. Nothing has cleared the problems.
Any suggestions as to what I may try next. Or does it sound terminal?
Many thanks
I would first try rebuilding the database from the App. This can take a little while but usually fixes this kind of issue;
The other thing I would try, before the database rebuild if you haven’t done that yet, is to do a power off restart of the Core. So not just turning it off with the front panel button. But unplug it from the mains, wait a minute and then plug it in again. It should restart normally and after a pause the music should appear in the app.
Thanks David.
Tried your “power off” suggestion and happy to say it worked fine. Fully happy customer again.
I’ll remember this one.
Many thanks.
