I have a UnitiNova and UnitiCore. Yesterday, a ripped CD cover would not display on the Nova. Then with the app I could not see any albums on the Core. Now it is not “discovered” by either the App, Nova or iMac.
I have tried powering it all down (including the ethernet extended they share) with no luck.
Should I just apply a full factory reset to the Core??
If you’re going to restart anything, it should be your main router (assuming that it runs the DHCP server for your network) not just the extender.
Seems a lot similar issues reported with the Core over the last month-or-so…
Any common denominators?
Yeah, the core.
