Well:
If the Core is wide awake with its lights on:
Network Sleep: A short press of the front panel button puts it into network sleep. The lights go off and some of the circuitry is powered down, but the Core remains discoverable in the app and on the network and can serve streams as usual. Itâs working from itâs linear power supply. The hard disc (if it has one), is still running 24/7. A short press wakes it fully up again.
If you just leave a Core alone, it will go to network sleep automatically when the preset time is reached.
Deep Sleep: a long press of the front panel button puts it into deep sleep. Most of it is off. The Core is now running on its SMPS power supply. The hard disc is shut down. A short press wakens it fully again.
Off: You have pulled the mains plug and there is no one home.
Restart: A long press to make it go into deep sleep. Then once itâs done that, a short press to wake it up again.
But if you arenât sure what mode itâs in because itâs misbehaving, then a power off restart, which means pulling the mains plug or switching off at the mains socket, means you can be sure itâs starting from scratch.
You donât need to leave it 10 mins or any of that nonsense. 10 seconds off is long enough.
So plug it back in, let it restart and itâs all back working again.
Factory Reset: This doesnât do anything to data (music) on the hard disc or SSD and doesnât reset the firmware to what it left the factory with, but it does clear all the internal memory of things best forgotten and resets it as if it had just left the factory with that firmware.
To do a factory reset, you put the Core in deep sleep, pull the mains plug, then holding the front panel button in, plug the mains plug in again. Keep holding the button in until the light by the front panel USB socket flashes, then let go the front panel button and let it finish restarting.
There has been some discussion on the forum that the above doesnât always work, so doing it twice wonât do any harm if you need to and also sometimes people have reported that you should listen for mechanical noises (relays, CD drive initiating) before letting the button go. I donât know I havenât done this often myself.
After a factory reset you have to set the appropriate drive as the music store (which is where the Core saves its own rips) and any shares which you want indexed. The Core will rebuild the index and this takes a while, say half an hour for 1000 albums, or thereabouts.
Is this what you wanted? Others may have things to offerâŚ
Best
