Hi there,
I’m in the process of buying a 2015 uniti-lite with Spotify capabilities but since I’m a Deezer member I was wondering if that is supported too.
Cheers Teo
Hi there,
Cheers Teo
There’s no built in support for Deezer, unfortunately. To get it to work on an ND5XS, you would need to connect an Airport Express or Chromecast Audio to its optical input. Alternatively, you could connect an iPhone to the USB port on the front panel.
Thanks, I thought so. I’ll work around it then.
Greets Teo
