Hello,
I was using my Uniti Nova today to listen to Soundcloud using the built-in Chromecast on the Nova. I was casting to it, and then pressed the up button on my iphone 11 pro, to raise the volume a bit. Instead, the volume went to max (I believe it actually went to 100 but I’m not sure) and the speakers immediately started clipping.
I panicked, and ran for the unit since I didn’t see the remote anywhere obvious. At this point, sound had been cut to the left speaker and was only coming out of my right speaker, but it was still full blast. I noticed something written on the Nova screen, a warning, I believe, that the sound had exceeded 96dB or something (it went by really fast) but I didn’t really take full notice because i hit the power button as soon as I could. Anyone know what this warning would’ve said?
After that, only my right speaker was working, no matter what I tried. Confirmed by playing music in the Naim app, going to audio settings, and adjusting the balance full to the right (unchanged sound) and then full to the left (basically no sound).
I then actually unplugged the speaker cables, plugged the right speaker’s cables into the left outputs of the Nova, and it still worked (but was obviously picking up the left channel of audio). So I don’t think the left stereo output on the Nova is faulty.
I did many deep sleep and restart cycles, unplugged the power and reconnected a few times, etc. Nothing worked. Eventually I switched the speakers back to the way they used to be connected, and my left speaker came back on miraculously, and sounded mostly fine except I started hearing noise and interference on the left (not the right) when trying to play a source connected to the preamp ins. Only on the left channel.
I tried a few restarts of the Nova, and sometimes, it just does not start up with any audio going out the left channel until I unplug the speaker cable going to the left speaker, and plug back in. I’m not sure if it’s a fault with the amp/Nova itself or if my speakers are blown or partially damaged.
But things have now seemed to return to a semblance of normal, and that noise hiss present on the left channel seems to be gone, although I’m never sure if the left speaker is going to work when I power the unit on without my jiggling cables in the back. I’m also noticing audio hum when playing the preamp ins (unity gain activated, using my home theatre receiver as source for the L/R channels).
Is there a way to see if the left outputs on the Nova are working, some sort of diagnostics? Is it possible to blow one of the stereo circuits? Or is it likely to be the protection circuit on the speakers themselves?
Also note, I had set my max volume on the Nova to 85 — so this should have been avoided!! Very upset that this even happened.
Does the max volume setting only apply to inputs native to the Nova (like Spotify, Tidal etc?) but not the Chromecast? It seems very dangerous to allow a remote source like a phone control the master volume, exactly because of problems like this. It makes me afraid to use this thing. I was petrified I had blown the left speaker of a set of Dynaudio Evoke 50’s, which cost me eight thousand dollars
I think this was a software issue. The Nova played at a sane volume when I began to cast, but then when I increased volume on the phone using the hardware button, it seemed to bypass the existing volume and go straight to max, i.e. synchronize the Nova’s volume with the phone’s volume, going straight to full. Super dangerous.
Just asking here if anyone on the forums knows of anything I can do to make sure the unit is functioning correctly and to protect against this happening in the future.
Thanks.
