Uniti Serve SSD shutdown
Quick question: Does the Uniti serve, SSD version, shut down and eject cd’s simply by touching the lit logo, or is a remote required?
If so, mine is not working in this regard.
I believe on the hd version you depress the logo to activate…
The two versions are the same. Press the green logo to eject a CD. To shut down, press and hold until the logo starts flashing, then wait until it stops before turning off the power button.
OK. Thanks much appreciated.
