Uniti Star & FM module
Hi all,
I would like to know if it is possible to tune FM radio stations ‘by hand’; the system offers automatic tuning. thanks
not in italy
ok, for DAB you are right, but my problem is on FM. I wanr to select frequencies but the automatic tuning skip whay I want
I think at if you go to the Now Playing screen for any FM station, you can then tune up or down to any frequency? ( can’t check that as I don’t have the FM/dab module in my Nova.)
yes, I can, but only with automatic search
Problem solved. Tnx to all
And the solution was…?
you have to tap continously on + and - until you arrive to chosen frequency.
